Selection filter issues
I´m having a problem while using the selection filter.
When I turn it on while i´m working with a subD, I can klick on a single point, edge or face, but i cant select multiple of them by drawing an rectangle.
I have seen it in servel videos but it wont work when i try it.
Are there any selection option where i can change it or what could the problem be?
Thanks
Hi Fabian -
Can you please run the Rhino SystemInfo command and copy-paste the result here?
Also, do you see this in a specific model only or also when you create a simple SubD plane, press the Selection filter: Vertices button and drag a selection rectangle over a few vertices?
Skjermbilde 2021-09-07 kl. 11.07.41
Thanks for your reply.
I tryed it with a simple plane, but that still doesn´t work
SystemInfo:
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Kommerziell, Build 2021-08-10
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 11-10-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 426.32
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-10-2019
Driver Version: 25.21.14.2632
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\FootMILL\Plugin\FootMill.rhp “FootMILLRH7” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
C:\Users\lohmann\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hell - does it make any difference if you disable FootMill in Options > PLug-ins page, and then close and reopen Rhino?
that was not the problem, but i found it.
in the options was RhinoOptions.General.ControlShiftSupObjectsSelect on False.
Turning it on true solft the problem
