When I start a Curve selection with CRhinoGetObject::curve_object in Rhino 8 in a command and the Curve is on top of a mesh the selection finds also mesh edges. This is very annoying and was not the case in earlier versions. Example:
____
unsigned int geometry_type_filter = 0;
geometry_type_filter |= CRhinoGetObject::curve_object;
CRhinoGetObject getInputObject;
getInputObject.SetCommandPrompt(L"Select 2 to 4 Curves");
getInputObject.SetGeometryFilter(geometry_type_filter);
CRhinoGet::result myResult = getInputObject.GetObjects(2, 4);
____
How can I avoid it programmatically? I know, when I switch off the “Mesh” filter in the GUI the selection returns only a curve or surface edge, but I would like to configure it in my code prior the selection.
I tried also getInputObject.SetGeometryAttributeFilter() but did not know what input to use.
