I set a RhinoDoc.SelectObjects += OnSelectObjects; event function for trigg a command,
the problem is , this “RhinoDoc.SelectObjects” is trigger on move object to.
This is a Bug??
thanks
This is a Bug??
thanks
When you modify an object (any type of transformation, etc) the original object is deleted, then the new updated object is added. You probably see then the selection trigger for that updated (new) object.
