Hello, I created a brick surface, and I am trying to select the breps that contain the points I generated so I can split them into two separate lists. When I use the point in brep command it does not select any of the breps. I also tried generating lines from the points and intersecting that way but that only selected two. Any help would be great!
Brick Arch 1.gh (30.7 KB)
Brick Arch Rhino.3dm (78.0 KB)
