Selecting an object changes print color
Can anyone recreate this issue in 6?
  • If the object is unselected it prints correctly.
  • If I have the object selected (like I’m going to use “Only Selected Objects” print) then the isocurve color does not match my “Display Mode” selection.
Hello - yeah, I see that - it looks like using print color will overrride the selection state OK but that does look wrong.
I take that back - I cannot reproduce it now. Can you post the file or send to tech@mcneel.com so I can test on the same object/color/.material, what have you, that you are using?
thanks,
