I’m trying to select the outer surfaces of a group of poly-surfaces.
I want to measure the area and solar incidence with laydybug and I therefore only need the outer surface…not the sides, nor the inner surface…and I have no idea how to do this…Any suggestions?
Thank you!
Sorry about only sharing a screenshot…I was in the early planning/concept stage and the building ended up much more complicated so I couldn’t use the bounding box method…but your suggestion helped me clarify the thinking a lot.
How would you recommend that I ’ compare the drawn vector with the normal of the panels’?
I working on a continuation of the same project and struggling with the comparison between two sector sets (one for the surface normal and a collections of normal vectors for squares on the same surface)…
Please don’t post multiple threads about the same topic. If you have additional information or questions it is better post again to the original thread.
