Select Rhino objects by type
Hello all,
I’m struggling with the new functions in grasshopper about rhino objects.
I’d like to pick only text objects belonging to a specific layer, I imagine it can be done through Querys and filters, but what is the appropriate syntax?
If someone knows the answer…
Thanks!
Is the text created as a curve / surface or are you talking about text created with !Text?
You can do this with the Pipeline component for points, curves, BReps, and meshes, but this tool does not support text objects or other object types.
It’s a text object
on the query model objects component you can expand and take only the “Annotation” output
Thank you for your answer. I thought that the new tools in Rhino8 could filter more object types. Unfortunately I couldn’t find more information about them.
