An old software I used had a “select previous” history. This has been discussed before in the middle 2010s but I can’t find any update.
You would input once and get the previous selection. Repeating it selected the previous to previous selection and so on. 3 to 5 steps would be useful.
If I’m selecting a part of a drawing for a client with some of the minor dimensions removed and notice a missing detail in the preview. Then have to do a small edit where something is altered - then the altered object becomes the target of SelPrev.
So I need to go through the drawing again and select all the objects I selected before for the print to PDF job.
With my old software I could hit
SelPrev - and get the newly edited object
hit SelPrev again and get all the objects I set up to print and I can add the edited object. In Rhino you would just hit the space key to go back each step.
I know there are ways of saving selections or naming selections, but they are much more complicated than “selprev” and then hitting the space bar to take another step back. PLUS I don’t know in advance if something has snuck in unintended or was missed out.
My previous software (long time ago) would allow up to 5 steps back using their version of selprev.
Cheers
MIK
