Select points of a surface
I have a question,
Is it possible to select point on a surface??
I am doing a chains of a jewellery piece, and I tried to select the inner quadrant point or the outer quadrant point of the jump ring, but I fail.
Is there ways to select points on a surface ?
58 AM
select _point, then activate the snap surface or polysurface. Alternatively, draw a curve with the _ExtractIsocurve command and then use the _point command and then snap curve
-Simon
Thank you !!!
BTW, I have another question,
How to set a white background instead of gird background ?
like this
ott-17-2017 08-20-12
Thank you very much!!
