Do you think there is a way to select every second point (the points highlighted in yellow)?
Thank you:)
Thank you:)
Thanks! I did ‘List Item’ and it worked too. However, your method might me more robust for a case when number of division changes and then I would not need to change the index for List item component.
Thanks
