I want to either select a polyline or create one from the command line. I managed to select one with Input.Custom.GetObject() or create one with Input.Custom.GetPolyline(), but I’m not sure if I can get from one command to the other.
I want to create an option in the selection command to jump to the creation command. Is this possible? If so, how?
public class TestPolyline : Command
public override string EnglishName => "TestPolyline";
var go = new GetPolylineObject();
go.SetCommandPrompt("Select polyline");
go.AddOption("Create");
var result = go.Get();
if (result == GetResult.Option)
return GetPolyline(doc, mode);
if (result != GetResult.Object)
return Result.Cancel;
var objref = go.Object(0);
var curve = objref.Curve();
if (null == curve)
return Result.Failure;
if (curve.TryGetPolyline(out var polyline))
RhinoApp.WriteLine("Polyline wth {0} points selected.", polyline.Count);
return Result.Success;
private Result GetPolyline(RhinoDoc doc, RunMode mode)
var gp = new GetPolyline();
var rc = gp.Get(out var polyline);
if (rc == Result.Success)
doc.Objects.AddPolyline(polyline);
RhinoApp.WriteLine("Polyline wth {0} points created.", polyline.Count);
doc.Views.Redraw();
return rc;
internal class GetPolylineObject : GetObject
public override bool CustomGeometryFilter(RhinoObject obj, GeometryBase geom, ComponentIndex ci)
if (geom is Curve curve)
return true;
return false;
