Is there a particular type of form modal that I need to use in order to be able to select objects in the Rhino viewports whilst the modal is open?
Currently by running a modal with either:
Rhino.UI.Dialogs.ShowSemiModal(MyForm())
or,
import clr
clr.AddReference("System.Windows.Forms")
from System.Windows.Forms import Application, Form
Application.Run(MyForm())
…allows me to add objects to the Rhino viewport, and rotate the view, but I cannot select the objects.
The modal doesn’t do anything as yet (displays a label), but eventually I was hoping to have selection events occurring in Rhino trigger actions in the modal.
