Select Objects on a layer in all layouts at once
is there a way to do that? sometimes I would like to do it… would be nice to select across all layouts… it is possible to switch between the tabs and repeat the layer selection and then edit all the geometry at once, but obviously that is time intensive with many tabs.
thnx,
Daniel
Hi Daniel - I’m not sure it fills the bill completely but I dredged up this old script which might be a start-
SelByLayer.py (1.9 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
it actually overfills it, slightly :))
thnx, much appreciated.
