Select objects inside fence?
Is there a way to select objects inside a drawn fence? Fence selection would be perfect if it would select objects inside rather than objects the line crosses.
You could try Lasso, despite the command line prompt that does tell you what you can do, many people do not realize that it allows you to click and drag repeatedly to draw a polyline instead of just holding the LMB down and sketching a curve.
