Rhino Version: Rhino 8 (Commercial)
Description of Problem: When right-clicking a layer (e.g., Strut Frame) in the Layers panel and choosing Select Objects, a valid closed solid polysurf assigned to that layer is ignored and not added to the selection set. However, the object can be manually selected in the viewport by clicking on it directly without issue.
Observed Behavior:
Right-clicking the layer and choosing Select Objects selects other objects on the layer, but skips this specific closed polysurface.
Clicking the polysurface directly in the viewport works normally, and the Properties Panel explicitly confirms:
Type: closed solid polysurf
Layer: Strut Frame
Diagnostic Steps Taken:
Block Check: Executing Explode on the object breaks it directly into individual surfaces, confirming it is standard geometry and not a Block Instance.
Sublayer Check: The object is on the main parent layer itself, not tucked away on an unselected child sublayer.
Lock/Hide Check: The object and layer are fully unlocked and visible.
Command Line Feedback: When manually selecting the object, the command history correctly logs 1 closed polysurface added to selection.
Expected Behavior: Right-clicking a layer and clicking Select Objects should select all geometry assigned to that layer, including this closed polysurface.
(Note: Attach your SystemInfo output and a stripped .3dm file containing the problematic object when submitting.)
SYSTEMINFO:
Rhino 8 SR34 2026-8-11 (Rhino 8, 8.34.26223.11001, Git hash:master @ f416e902495235e4e4a45cfc29ff1320cc8c70d8)
License type: Commercial, build 2026-08-11
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Computer platform: LAPTOP - Unplugged [85% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 4-16-2025 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.6737
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 4-16-2025 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.6737
> Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.6737
Driver Date: 4-16-2025
Driver Version: 32.0.101.6737
Z-Buffer depth: 24 bits
Total Video Memory: 2097148 KB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.34.26223.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.34.26223.11001
