Select Object, Make Active Layer
Is there a way to select an object, and make the layer that the object is on the active layer so when I draw some geometry it is on the same layer ? tia :slight_smile:
That would be the _SetLayerToObject command…
thanks Mitch, knew it was out there somewhere :slight_smile::+1:
