Select Multiple Bolts Array with window select
i have a problem can’t select bolts with window select to set them i try with model objects component but it’s require to select each bolt array seperated is there is any way to solve that ?
this seems to be an old API problem, it’s the same with reference models - you can’t area select them through the API.
Here’s a possible workaround using a scripting component:
ReferenceSelectedObjectsScript.gh (11.8 KB)
pic:
First select any objects in the TS model using e.g. area select, then trigger the scripting component to reference in any selected objects into GH.
Cheers,
Sebastian
thank u very much
