Hi there,
I have a list of objects and was hoping to select all of the circles in the list. There are numerous tests that could be performed on the list to select the circles, but it appears that they are already recognized by Grasshopper in the Note object:
You can use member index to search for matching text.
Alternatively, if you plug in a Circle component it will output only the circles and provide null items for everything else. But if you want to avoid creating nulls and use descriptions then the first method should work for you.
