Hi all,
please can someone help me, how to select from selection?
I worked before with Autocad and there it made command “quick select”.
E.g. I have four object in a drawing. I select only one and than I want to select only one layer in this selection.
If I use command select layer, then are selected all elements of that layer in all object. But I want select the elements of one layer only in selected object…
Please can you help me with that?
Thank you a lot!
Y.
Sounds like your “objects” are either blocks or groups… I’m not sure there is a way in Rhino to select only the objects on one layer inside a group or block without a script.
With a script, it should be possible to do what you want if your objects are groups; with blocks, not, as a block is considered as a single object.
