Select Edges too Thin - ON FILLETEDGES and other commands
Hello guys, im having trouble with Rhino 6, on selecting edges. Appears to thin, testing on a “sweep2” seams that is a problem with the order of selection, as you can see on the images.
The first image is using Filletedge, the second is the sweep2, when i click on the second edge the thicknesse comes back to normal (rhino5)
Hello - I suspect this is video-card related - so far it looks correct here- can you run SystemInfo (Help menu > System information) and paste the results here?
thanks,
Thanks for the fast reply Pascal. Here is the information:
Rhino 6 SR1 2018-2-6 (Rhino 6, 6.1.18037.13441, Git hash:master @ 5a33e6871b94d32ba552468218cef0ad8d3d1263)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
AMD Radeon ™ R9 380 Series (OpenGL ver:4.5.13492 Compatibility Profile Context 22.19.677.257)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 9-22-2017
Driver Version: 22.19.677.257
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\OptionsManager.rhp “Rhino Options Manager”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Or perhaps TestWireThicknessScale
Doenst affect the selection ON commands, only on normal selection
Hello - well, standard first step for display issues is to recommend the latest driver - yours does not seem terribly ancient but it might be worth getting the latest from the ATI website none the less and see if that does anything good.
Will try that and post the results here. Thanks for now guys!
