Select edge through object
I used to be able to select an Edge by simple clicking through an object in Shaded and Rendered mode in other versions of Rhino. But after I upgraded to Rhino 7, I can’t do it anymore. Is there any options that could enable this?
Usually when I’m facing this problem I switch the graphic display to “Ghosted” or “Wireframe” and that helps me select the concealed geometry
But this wouldn’t happen in Rhino 5. I could select edges through objects without changing display
