Select by Print Colour
Hello there,
I’m wondering if its possible to select items which have similar print colour to the selected object? Just like the Selcolour command?
Best,
Jeremy
Here are two from my library…
SelObjsByPrintColor.py (2.5 KB)
Selects objects by their print color, either choose an object to match
or choose an RGB color to find.
(Excludes blocks)
SelObjsPlusBlocksByPrintColor.py (4.4 KB)
- handles blocks and nested blocks (partially). By default, only blocks containing
all elements with specified print color will be selected. Pass a False argument
at bottom - SelObjsByPrintColor(False) - and it will select block instances with
at least one matching color.
- does not allow selection of a block instance for reference print color
Edited - script links were in the wrong order relative to the descriptions…
Thank you again Mitch :slight_smile:
-Jeremy
