Hi there,
I wonder whether this is a bug or not meant to work: I have an object which I need to enlarge for 3mm in height, so I select the upper surfaces with shift+command+click, click the extrude ball and type in 3mm – but it doesn’t work, only the gumball disappears. If I do it surface by surface, it works.
Shouldn’t it work for several surfaces as well? Not a big issue, of course, but I wonder.
Best regards - Jan
Extrude-problem.3dm (4.0 MB)
