Hi Guys,
Good day, got a challenge wherein l have a revit elements with different instance parameter values and l want to select an element from its specific parameter value and put them in different color?
Any help?
Thanks.
Hi Guys,
Any help?
Thanks.
Hi, Joel
You’re going to need the latest release to add the View Filter & Override.
https://www.rhino3d.com/inside/revit/1.0/reference/release-notes
Requires 3 walls with Red, Blue, Green in the comments.
Re_View_Filters.gh (15.4 KB)
Thanks Japhy, is the named “MyColor” is referring to instance parameter and the colors are the values?
Cheers.
Thanks Japhy, what if l got a new instance parameter and not coming from the as built parameter, is this going to work?
Cheers.
Thanks Japhy, kind regards.
Hi Japhy,
I added the color names on the comment parameter but I encountered these errors?
Is there anything I missed?
Thanks.
Right click the C on the red component and set the category to Wall.
