SelDup with different object types?
Hi, is there a way to find overlapping objects of different object types? E.g. when an extrusion is identical with an overlapping mesh? SelDup finds only identical and overlapping doublets of meshes or doublets of extrusions. In the attached file SelDup finds the 2 overlapping extrusions (blue circle), but it doesn’t find the overlapping mesh and extrusion (green circle). How can I do this?
SelectOverlapping.3dm (121.4 KB)
Who can help me on this topic?
Hi Cutair,
This is not the same as SelDup and takes more work but you could use point deviation to check for the distances between the objects.
Ciao… utilizza i filtri
Buon lavoro.
Dear byrkow, thank you. What do you mean with “use the filters”? Which filters? Please give an example.
Dear byrkow, thank you. I’m afraid but this is not what I’m looking for. It should be something similar to SelDup.
I want to select all overlapping objects even if they are of different object types. E.g. when an extrusion is identical with an overlapping mesh. SelDup finds only identical and overlapping doublets of meshes or doublets of extrusions.
Do I need to select only the objects that completely overlap? It seems like a separate script would be required.
Dear JinYoung-Go, thank you. I want to select the objects (polysurfaces and/or meshes) that occupy exacly the same volumetric space. Please refer to my initial post (post 1). “SelDup” finds and selects the 2 polysurfaces (blue circle) but it doen’t find the polysurface and mesh inside of the green circle. These two objects occupy exacly the same volumetric space but they are of different types (one is a polysurface, the other is a mesh). What do you suggest?
SelDupAnyType.py (13.6 KB)
Here is the Python script, SelDupAnyType.
It can be run via ScriptEditor or assigned to an Alias:
_-ScriptEditor _R "FilePath\SelDupAnyType.py"
Check the video for reference. (Created with AI assistance.)
Dear JinYoung-Go, thank you. Your py-script works and solves my issue.
