Test macro
_Point w-10.0,0.0
_Point w-9.99999999,0.0
_Point w-1.0,0.0
_Point w-0.99999999,0.0
_Point w0.0,0.0
_Point w1e-08,0.0
_Point w1.0,0.0
_Point w1.00000001,0.0
_Point w10.0,0.0
_Point w10.00000001,0.0
_SelNone
_SelDupAll
Even though there is only 1e-8 deviation within each point pair, only the points closest to the World origin are not selected by _SelDupAll.
Below is a report of maximum distance thresholds of GeometryEquals for Points at various coordinates.
Nominal x | Max dist where GeometryEquals still returns True
-100 | 3.8146972727304300e-06
-10 | 4.7683715909130300e-07
-2 | 5.9604644886412900e-08
-1.5 | 5.9604644886412900e-08
-1 | 2.9802322443206500e-08
-0.1 | 2.2351741776893700e-09
-0.01 | 6.8917870629098300e-10
-0.001 | 1.0710209520474500e-11
0 | 7.0064923216240900e-46
0.001 | 1.0570511208962000e-10
0.01 | 2.4214387005921900e-10
0.1 | 5.2154064053566700e-09
1 | 5.9604644886412900e-08
2 | 1.1920928977282600e-07
1000 | 3.0517578181843400e-05
10000 | 4.8828125090949500e-04
Script for GeometryEquals study
#! python 2
from __future__ import absolute_import, division, print_function, unicode_literals
import Rhino.Geometry as rg
def get_max_geometry_equals_distance(x):
Finds the maximum distance (delta) added to x where
pt1.GeometryEquals(pt2) still returns True.
p3d1 = rg.Point3d(x, 0.0, 0.0)
pt1 = rg.Point(p3d1)
low_delta = 0.0
high_delta = 1.0
pt2_high = rg.Point(rg.Point3d(x + high_delta, 0.0, 0.0))
while rg.Point.GeometryEquals(pt1, pt2_high) and high_delta < 1e10:
high_delta *= 2.0
i = 0
while True:
mid_delta = (low_delta + high_delta) / 2.0
if low_delta == mid_delta or high_delta == mid_delta:
break
p3d2_mid = rg.Point3d(x + mid_delta, 0.0, 0.0)
pt2_mid = rg.Point(p3d2_mid)
if rg.Point.GeometryEquals(pt1, pt2_mid):
low_delta = mid_delta
else:
high_delta = mid_delta
i += 1
return low_delta
def main():
x_values = (
-100.0,
-10.0,
-2.0,
-1.5,
-1.0,
-0.1,
-0.01,
-0.001,
0.0,
0.001,
0.01,
0.1,
1.0,
1.5,
2.0,
10.0,
100.0,
1000.0,
10000.0,
print("{:<15} | {:<22}".format("Nominal x", "Max dist where GeometryEquals still returns True"))
print("-" * 66)
for x in x_values:
max_dist = get_max_geometry_equals_distance(x)
print("{:<15g} | {:<22.16e}".format(x, max_dist))
if __name__ == '__main__': main()
