Is there a command to select Cylinders in Rhino? As in, those objects created with the ‘Cylinder’ command?
Thanks,
Dan
Thanks,
Dan
Some discussion happening here:
Scripting SelBox and SelVolumeSphere - Scripting - McNeel Forum
No. It’s just a NURBS surface.
Unlike applications like AutoCAD, Rhino does not use a bunch of different object types. You may have to get creative to select them specifically.
With some ChatGPT help
import scriptcontext as sc
import Rhino.Geometry as rg
def select_extrusions_with_circle_profiles():
# Get all the extrusion objects in the document
extrusion_objects = rs.ObjectsByType(rs.filter.extrusion)
# Create an empty list to store the selected extrusion objects
selected_extrusions = []
# Cycle through each extrusion object
for extrusion_obj in extrusion_objects:
# Check if the profile curves of the extrusion are circles
if is_circle_profile(extrusion_obj):
# Add the extrusion to the selected list
selected_extrusions.append(extrusion_obj)
# Select the extrusion objects with circle profiles
rs.SelectObjects(selected_extrusions)
def is_circle_profile(extrusion_obj):
# Get the underlying Brep object of the extrusion
brep = rs.coercerhinoobject(extrusion_obj).Geometry.ToBrep()
# Get the edges of the Brep
edges = brep.Edges
# Check if any edge is a circle curve
for edge in edges:
if edge.IsCircle():
return True
return False
# Call the function to select extrusions with circle profiles
Hi Dan - Cylinders are generic ‘extrusion objects’ by default - they are not tagged by how they are created. It would be possible to do some fancy checking in a script to find things that are probably created by Cylinder but it would not be possible to, for example, distinguish cylinders created by Cylinder from extruded circles.
@lignindes - here’s a thing that may help -
SelCylinder.py (1.3 KB)
To use the script set up a macro like so, that you can put on a button or alias:
! _-RunPythonScript “Full path to py file inside double quotes”
