For the first time I needed to use SelCircular to try and select a group of objects contained within another circular object without selecting the outer container… It works OK for that except…
Once you set the selection circle center, you are in “screen space” and no longer in model space. If you need to zoom or pan the view once you have set the selection center, it moves with the view and is no longer centered on the objects you wanted… Which makes its usefulness much more limited, unfortunately…
Could this be “tuned up”? Could the selection center follow the original point chosen in model space?
Thx, --Mitch
