i have some duplicated edges on a surface, explode, ran SelChain
, set curve only selection filter and it is letting me select surface edges.
it should respect the filter shouldn’t it?
technically, a surface edge is interpreted as a curve in several tools. You’d have to use the pick sorter to determine which is which.
ok, thank you
