Hi I want to use SelBrush function in Python.
There is one more thing, I want to pass a curve to this SelBrush function.
Is there is a way to do this?
I tried but I can’t pass an object.
Could you look at my code?
objs = rs.GetObjects(“Wybierz element”)
rs.Command("SelBrush Curve " + str(objs))
Try:
_SelBrush _Curve _SelId <id>
Were <id>
is the id of your curve object.
For example:
_SelBrush _Curve _SelId fecf06e5-1e4d-4a63-a1b8-60145f843ff1
– Dale
Oh it works!
Thank you so much!
There is one more problem
Message: unable to convert 2f840475-6ffc-49a3-9db1-b983892690d7 into Brep geometry
objs = rs.GetObject(“Select element”)
rs.Command("_SelBrush _Curve _SelId "+ str(objs))
How about this?
crv_id = rs.GetObject("Select element", rs.filter.curve)
if crv_id:
rs.Command("_SelBrush _Curve _SelID " + crv_id.ToString())
– Dale
Perfect!
Everything’s works great.
Thanks
