Segmenting a torus
Hi, I need to take a segment of a Torus. The approach I am trying is to use the Rhino.Geometry.Brep.Trim method. However, the functions to convert a Torus into a Brep seem not to work. Both Rhino.Geometry.Brep.CreateFromTorus and Rhino.Geometry.Torus.ToBrep result in an error message “Message: ‘type’ object has no attribute ‘CreateFromTorus’”. According to Rhino documentation, both functions should be supported.
What is wrong here? Thanks.
This seems to work here:
#! python 3
import scriptcontext as sc
import Rhino
plane=Rhino.Geometry.Plane.WorldXY
torus=Rhino.Geometry.Torus(plane,50,10)
brep=torus.ToBrep()
sc.doc.Objects.AddBrep(brep)
sc.doc.Views.Redraw()
As does this:
#! python 3
import Rhino
brep=Rhino.Geometry.Brep.CreateFromTorus(torus)
I haven’t tried trimming, but the brep is created, no problem.
I copied your exact same code but get the error message again
What could be wrong on my side?
Hmm, odd, it works here in either the V8 new ScriptEditor (Python 3) or the old EditPythonScript (Iron Python 2). Can you run SystemInfo in Rhino and post the results here?
I tried both using EditPythonScript and ScriptEditor and get the same error message.
Here you have the SystemInfo log:
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Commercial, build 2023-10-31
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 2-21-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5333
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 2-21-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5333
> Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.5333
Driver Date: 2-21-2024
Driver Version: 31.0.101.5333
Z-Buffer depth: 24 bits
Total Video Memory: 128 MB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23304.9001
Thanks!
First thing is to update your Rhino, we’re on SR 9…
Note also that your video card is totally inadequate for Rhino… writing scripts might work, but running them and creating objects that will be seen onscreen may not…
Updating Rhino solved the problem… Thanks!
