Hi Jon
I opened the exercise file “00-111029 Tekla-Model-Portal frame.gh” and find that the beam section seems can’t display correctly. Is there anything going wrong? I’m using Rhino6 and installed " [ggRhino6Tekla2018 v1.4.06.msi]"
Hi Jon
Please make sure you have your rhino units set to mm for this example…if you change you units in rhino reload grasshopper with the example.
Let me know if you are still having issues.
Cheers
Nathan
19:1062664
Hi Nathan
thank you for your kind reminder. It works well now
