See values of input
Hi
Is it possible to see the values _RADMaterial picks up:
billede
And if it is, how do I do it?
In a Panel maybe, like this?
You should install the Sunglasses GH plug-in, it lets you zoom in on inputs and outputs and it’ll show in most cases some of the info
Hej Morten -
If you connect a panel to the component that feeds into the _RADMaterial_ input, does that give you the information that you need? If not, perhaps the RADMaterialsInfo component is what should be used here?
You might want to check Ladybug Tools | Forum for any questions related to the Ladybug Tools.
It is a string connecting to a material library :
I just want a kind of doublecheck to see if it collects the correct values.
Im gonna give the sunglass plugin Nathan suggested a go
