How is it possible that sections set up at worksession don’t work? I have changed my workflow, and I get strange behaviours of these… Or maybe I do something wrong?
So, I have several models with geometry (various types, some of them pure VA objects, some regular Rhino geometry, some with "embedded and linked blocks). Then I have a “master” file - just an empty file, without any geometry, just levels, sections, views and so on. Using this model I set up a worksession - let’s say 10 models. So far it works fine. At layouts I can put live plans and sections, all the interactions, materials etc. seems to be perfect. And then I need to get a regular section, just to export it. So I use the “_vaSectionView” command, I can see quite fine entities and… that’s all, I cannot export them. I try to use “export selected” but it doesn’t work. Firstly, after chosing the command I cannot select any section view. I try to preselect the view, just before using export command and it seems to be OK. Until I open the new file, it is quite empty. Not a single line…
I tried the same, with a model as a initial file - it is almost the same effect. The initial model can be seen at sections, and none of the attachments…
So, what can I do with the problem?
Cheers, Jaro
