Hello!
ClippingSections command > option Dir > Custom
When trying to set the axis manually parallel to Y, it gets set to X.
Thanks!
Hello!
Thanks!
Hi Eugen, I’m not able to repeat this. What version are are you running?
I’m testing on 8.0.23257.04301
Edit: I think is see what is going on. If you choose custom and then try to pick an X or Y manually it change your option.
If picking Custom and then manually picking the X you’ll get CPlane option. This isn’t consistent with the Y selection.
Thanks for reporting youtrack
