Though set at 1-1/2” text height as displayed in the new section panel, it was displaying at about 6’. When adjusted in the section panel to 3”, it had no effect. It was set at 3’ when I opened section styles, and setting it there adjusted it to 3” finally. This has been a common issue over the years, and that’s been the only way to rectify the issue. It seems to reset itself to enormous text size from time to time. Maybe it’s because my project units are feet.
Hi @djhg, in VisualARQ 3 the Section object will take the text size assigned by instance (in the Section Object Properties, in the Rhino Properties panel), when the style has the “Annotation” set to “By Object”.
Otherwise, it will take the dimension of the text size assigned by style:
If this value is taken “By Annotation Style”, it will change if you edit that Annotation Style in the Rhino Document Properties.
