Section style boundarylines not visible
Hi!
Since the last update the boundrylines in sectionview are not visible.
Before:
What I see now:
Is this a bug or what can I do about it?
Hi Sanne -
Please post both a 3dm file that we can check and the output of the Rhino SystemInfo command.
Hi Wim,
Hereby the system info and 3dm file.
System info_Showcase 2.5m.txt (2.6 KB)
Showcase 2.5m.3dm (5.6 MB)
Hi Sanne -
Just to be sure, are the images you posted from the Rhino viewport or from a PDF that was printed from Rhino?
The first is from the pdf I printed previously, the second image is from Rhino viewport, but when I print to pdf I see the same.
Thanks. Could you post that pdf file? Also, do you know which version you were running previously?
Alpla - Showcase 2.5m.pdf (451.9 KB)
I’m not sure which version I was running before.
