Section now groups
Hi.
While using “Section” command, if I set “AssignProperties=ByInputObject”, output curves are added to the polysurface groups and I need to ungroup curves and objects. Also “GroupObjectBySectionPlane” variables is set to “No”. In Rhino 7, this command was working properly.
Thanks.
Baris
Hi Baris -
I moved your post from that long thread…
I’m not seeing that here in a quick test. Could you post a simple 3dm file that shows this behavior on your end?
Hi Wim,
Thank you very much for your kind attention.
I attached my file, I just selected all polysurfaces and run “Section” command. Curves was able to be moved freely after the command produced section curves but after unselecting, when a curve is selected, polysurfaces are selected too.
I hope it is my fault and no extra work needed for your side.
Best regards.
Baris
M08.3dm (7.2 MB)
Thanks for that file, Baris. I see what you mean.
RH-76578 Section: Don’t use the Group attribute of the input
Thank you very much Wim.
Have a good day.
Regards
RH-76578 is fixed in Rhino 8 Service Release 13
