I am trying to make sections on this Mobius and the sections to be in a polar array , 60 sections. Is there a command for Section in polar array? I am trying to make the sections follow the shape of the Mobius as it goes around. I did a section in Polar Array but it does not follow the shape, it just multiply around without pivoting to follow the shape.
I am unclear what you are seeking here. The centreline of your mobius is a planar circle. If you draw lines perpendicular from the centreline, they will lie on vertical planes. I sense that you do not want that.
Are you hoping for planes that are perpendicular to the centrelines of individual faces, as here?
If instead you take a simple vertical section and skew it to suit one face at a particular point, it doesn’t suit the other three faces and becomes unsuitable to the original face as you progress around the form.
(This is created by making a polar array of planar surfaces and either using _IntersectTwoSets between the array and the mobius to create planar curves or using the mobius to trim the planes to create aligned surfaces.)
Thank you for that! Starting with planar SRF is the key, I have never used -Intersect two set before, I have used -Intersect object many time but never this one. . Much appreciated, thank you again. Great help.
