Got a bug with section cuts. The lens length occasionally changes to a giant number and the camera position that’s perpendicular to the direction of the cut will also change to some giant number and the cut will no longer display correctly.
Hi @Clayton_Muhleman we have seen this error in other files, and it seems to be caused by Guides. If you delete them and fix manually the giant number in the viewport camera properties, this issue might go away. We will fix this as soon as possible.
@Clayton_Muhleman, this issue has been fixed in VisualARQ 3.5.1. If you still see wrong values in the Viewport Camera values, just change them manually to a reasonable value. They should not be corrupted anymore, so you can work with guides confidently now.
