Section Color
I need to update some images I made with a previous version of Rhino (probably 7) that look like.
In Rhino 8, my sections are coming out as Gray (black being the object Color). All my tweaking has gotten me gray. How can I get them to come out red again?
A direct answer will require you to post a file.
Multiple things can control section color. The Display modes and “use section styles” - and note that when some options are grey’d out, they still affect appearance, so temporarily checking a box, changing a setting, and unchecking the box, can cure that. There’s a few settings here but going into further details is a waste without knowing how things are set up.
If section styles are enabled then you have to check the layer the object is on and set up a section style.
Clipping planes themselves can control settings and in some cases might override them.
And… object settings can override other settings (for example, ‘byLayer’).
But ya… a real solution is probably close at hand if you can post a file, even just a simple one.
