Section at an angle to parallel views
I want to do a section on an angle and produce parallel views. Do I rotate the object to the parallel view orientation and then do the clipping plane?
EDIT: Ugh this is actually a bit unintuitive. The Order is: Make a clipping plane, flip it, cplane from object, rotate cplane around its z axis 180 degrees, flip clipping plane again, use Plan command.
I guess i will write a small makro/ script after breakfast.
sectionn parallel.3dm (40.9 KB)
