Seamless transitional perforation pattern - Circle to Square
Im attempting to create a custom perforated panel that begins as circle perforations and ends as squares.
Ultimately I will also need to use the image sampler to create an image using just the square portion of the pattern.
Not sure how hard this is to pull off… Any ideas?
Pretty easy.
wow! Im just getting into grasshopper so to me this looks complicated but thank you so much!! This is extremely helpful. Im kind of understanding what your doing here. Would this setup work if I then plug it into an image sampler?
Have you ever used an Image Sampler? Go for it!
