When I create my Dock Bar project, when I look at the RhinoSdkUiDockBarDialog.h file, it has this error???
In another project similar to this this does not happen. What’s missing from my project??
You may need to disable the Intellisense warnings in Visual Studio, this looks like an error you can ignore. Unless your project does not build, any build errors need to be fixed.
Hi Menno,
I need to create a Dock Bar, however I am having a lot of difficulty doing so.
When I create a common Dialog without a problem, now when I go to transform it into a Dock Bar, that’s when the errors start…
Is the dock bar part of your plug-in project?
Yes, I have any plugins that use Dialogs, and now we wanted use Dock Bars…
Ok, have you seen the example plug-in here
Menno,
Yes, I had already accessed this link, what I can’t do is create a new file, it presents me with a series of errors that I can’t find a solution for…
Would it be too inconvenient to give you my project so you could give me more targeted help?
If so, how could I send this project?
I can’t really help you before coming Monday. You’re welcome to zip your project & share it here, there are maybe others who can help before I’m able to do so.
I’m putting a zip file in Drive to download
