Scripting date/time setting?
Is there away to change date/time from the command line? I want to make a simple sun study using neon and a crude script to render, change the time ten minutes (or whatever interval), then render again, repeat…
I’m still hoping the animation toolbar gets hooked up to use it properly with Neon at some point…
@andy : I guess there’s no way to script this, or nobody that’s seen this that knows a solution… any possibility of Neon being worked into the animation/sun study toolbar in the future? Thanks…
The sun time can be scripted using -DocumentProperties _Rendering _Sun
Ah, thanks… I just could not find that for some reason! (I take it the animation toolbar question is still an unknown?)
Thanks…
