Scripting and Macros examples are useful in the documentation.
I’m making a button for importing mesh from an external UV editor.
But I wish to interact with the _Import command and I do not know where to look in the documentation.
It looks like is missing the Rhino buttons command section.
If i hit in the rhino web page, “learn” I go to tutorials:
https://www.rhino3d.com/tutorials
And at that point, I get lost looking for a command macro section for programing simple buttons.
Looks like missing the command line macros
How to Import using a custom command macro button?
Here is the result of what I was looking for.
Button to import always the same object.
! -_Import
“X:\path\mesh.obj”
MapYtoZ=Yes
enter
This macro is useful in my case because I’m exporting the mesh to RizomUV and back in a fat way after applying some UV mapping modifications.
Where I can find all the other options like MapYtoZ=Yes for OBJ in the documentation?
I think this kind of scripting command button example can help in the documentation here:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#fileio/wavefront_obj_import_export.htm
As is done for example for FBX scripting as a side note (should call it macro?):
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#fileio/motionbuilder_fbx_import_export.htm%3FTocPath%3DFile%20I%2FO|File%20Formats|_____24
In PHP documentation, users can place a code example close to the command and others can upvote them.
