How to get the first two points of a leader with ortho turned off and the final point with ortho turned on.
It seems like it would be easy peazy, but…
Hi Cliff,
_SetOrtho _Off _Leader _Pause _Pause _SetOrtho _On
or simply press the Shift key to toggle Ortho while picking the points.
Thx, Jess.
Here’s what I now have:
strBlock = Rhino.GetObject("Select block: ", 4096)
strName = Rhino.BlockInstanceName(strBlock)
Rhino.Command"_SetOrtho _Off _Leader _Pause _Pause _SetOrtho _On _Pause _strName "
How do I get the block name into the leader and dispense with the text input dialog without the user seeing it at all?
You might also look at this:
https://github.com/mcneel/rhinoscript/blob/master/BlockLeader.rvb
Hi Cliff, here a modification with the ortho constraints.
Option Explicit
Sub BlockLeader()
Dim arrBlock
arrBlock = Rhino.GetObject("Select block instance", 4096, True)
If IsNull(arrBlock) Then Exit Sub
Dim strName
strName = Rhino.BlockInstanceName(arrBlock)
Dim aP1, aP2, aP3
Dim strTempLine
Call Rhino.Ortho (False)
aP1 = Rhino.GetPoint("Tip of leader arrow")
If IsArray(aP1) then
aP2 = Rhino.GetPoint("Next point of leader", aP1)
If IsArray(aP2) then
strTempLine = Rhino.Addline(aP1, aP2)
Call Rhino.Ortho (True)
aP3 = Rhino.GetPoint("End point of leader", aP2)
If IsArray(aP3) Then
Call Rhino.AddLeader(array(aP1,aP2,aP3), , strName)
End If
Call Rhino.DeleteObject(strTempLine)
End If
End If
End Sub
Call BlockLeader()
Perfect. Thank you both so much.
