Scripteditor
Can i get some help with this?
Hi Harold,
please run SystemInfo in your rhino command line and post the results.
To reset your rhino python environment close Rhino then delete %HOMEPATH%\.rhinocode folder and restart Rhino.
Run Scripteditor command and let it initialize, running RhinoCodeLogs saves the logs to a text file.
New Text Document.txt (2.7 KB)
I think I fixed it. My company was blocking part of the installation. I disconnected it from the company network, connected to a hotspot, and reopened it. That did the trick. Thanks for the reply!
I had this last week in the BETA. Deleting the contents of the .rhinocode folder helped. I had to install all the python modules again.
Same here i am installing modules again too
Maybe it works if you just copy the old files if you made a backup of them. The reason I didn’t do it was because I didn’t know which file breaks the chain and it would take longer to troubleshoot that instead of installing everything from scratch again…
I’m just going to add them again as I go. I’m afraid of breaking it again.
