Sorry I missed this. Will test today and report back.
Update:
I can see errors on Windows. Somewhat different from what is listed in your ScriptEditor.log file above. I will dig more.
pip install error | Collecting wood-nano==0.3.5
Using cached wood_nano-0.3.5-cp312-abi3-win_amd64.whl.metadata (3.1 kB)
Collecting compas-wood==2.4.0
Using cached compas_wood-2.4.0-py2.py3-none-any.whl.metadata (3.7 kB)
Collecting compas
Using cached compas-2.15.0-py3-none-any.whl.metadata (7.0 kB)
Collecting wood-rui==0.2.2
Using cached wood_rui-0.2.2-py3-none-any.whl.metadata (807 bytes)
Collecting compas
Using cached compas-2.8.1-py3-none-any.whl.metadata (7.2 kB)
Collecting jsonschema (from compas)
Using cached jsonschema-4.26.0-py3-none-any.whl.metadata (7.6 kB)
Collecting networkx>=3.0 (from compas)
Using cached networkx-3.6.1-py3-none-any.whl.metadata (6.8 kB)
Collecting numpy<2,>=1.15.4 (from compas)
Using cached numpy-1.26.4.tar.gz (15.8 MB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Installing backend dependencies: started
Installing backend dependencies: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
Preparing metadata (pyproject.toml) did not run successfully.
exit code: 1
[22 lines of output]
+ C:\Users\ein\.rhinocode\py313-rh9\site-envs\timber_connections_v9-bWDqDPGP\Scripts\python.exe C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c\vendored-meson\meson\meson.py setup C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c\.mesonpy-_adypuw0 -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md --native-file=C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c\.mesonpy-_adypuw0\meson-python-native-file.ini
The Meson build system
Version: 1.2.99
Source dir: C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c
Build dir: C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c\.mesonpy-_adypuw0
Build type: native build
Project name: NumPy
Project version: 1.26.4
C compiler for the host machine: clang (clang 19.1.5 "clang version 19.1.5")
C linker for the host machine: clang link 14.50.35724.0
C++ compiler for the host machine: clang++ (clang 19.1.5 "clang version 19.1.5")
C++ linker for the host machine: clang++ link 14.50.35724.0
Cython compiler for the host machine: cython (cython 3.0.12)
Host machine cpu family: x86
Host machine cpu: i686
Program python found: YES (C:\Users\ein\.rhinocode\py313-rh9\site-envs\timber_connections_v9-bWDqDPGP\Scripts\python.exe)
Need python for x86, but found x86_64
Run-time dependency python found: NO (tried sysconfig)
..\meson.build:41:12: ERROR: Python dependency not found
A full log can be found at C:\Users\ein\AppData\Local\Temp\pip-install-1sjxxqvf\numpy_ebe1637807d245d2acf0e5785c6d508c\.mesonpy-_adypuw0\meson-logs\meson-log.txt
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
Encountered error while generating package metadata.
See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
macOS seems to be fine on the first try. Is there a wood-nano test I can run to ensure it loads and works?
