ScriptEditor - Polyline read as PolylineCurve
Hello everyone,
as you can see from the attached example I set the node input as a Polyline:
but after building the project with the ScriptEditor (available for Rhino 8) the node gives me an exception:
Do I miss something?
Best Regards
Luca
Test pline ScriptEditor.gh (6.8 KB)
Test pline ScriptEditor.Components.gha (34.5 KB)
A polyline is more or less a collection of points.
While a PolylineCurve derives from Curve,
you can ToPolyline() to get the underlying polyline from a polylineCurve
please post the code that causes the error.
Curve inputCrv;
Polyline polyline;
if (inputCrv is PolylineCurve pCrv)
  polyline = pCrv.ToPolyline;
else
  // error handling
// alternative
if (inputCrv.TrygetPolyline(out polyline))
// or if you prefere
if (! inputCrv.TrygetPolyline(out polyline))
  // error
  return;
// ... go on with your logic here
Thank you I finally understand.
I set the input as Curve (not as Polyline):
private void RunScript(Curve inputCrv, ref object a)
        Polyline polyLine = new Polyline();
            polyLine = pCrv.ToPolyline();
        int npts = polyLine.Count;
        a = npts;
Test pline ScriptEditor_rev.gh (6.1 KB)
Test pline ScriptEditor.Components.gha (35 KB)
without testing - do something like this.
and test it with a non - polyline curve.
        // defaults and error
        a = null;
        Polyline polyLine = null;
            // success on polyline input
            a = npts;
